  3. max_transition violations
  • Subscribers 92
  • Views 14058
vimalraj205
vimalraj205 over 12 years ago
 hai friends,
how can i find the pins that are violated by max_transition violations
 any command?
plz_help
  • wally1
    wally1 over 12 years ago
    After you run timeDesign the output directory will contain a *.tran file. Default is timingReports/designName.tran. This file contains the max transition violations.
    - Brian
  • vimalraj205
     yes brian,
    i need to write a script for reducing the max_transition violation
    when i use the command  get_property [get_pins $pin_name] max_transition this gives a value different from
    the value got by the command  dbGetMaxTrans & dbGetMaxTransSlack for the particular pin and also a different value in the reportfile
    so i need to confirm which one is correct or   is there any simplest way to do this job
     hlp me
     thank you
    -vimal.
