  3. Error in running foundation flow
  • Subscribers 94
  • Views 16345
Arslan
Arslan over 13 years ago
Hi, I made the foundation flow scripts using foundation flow wizard. I have successfully run init, place, prects, cts, postcts but when i run route using "make route" following error occurs :-
**ERROR: (ENCTCM-10):    Failed to set value for option "-fixHoldAllowSetupTnsDegrade".
**ERROR: (ENCSYT-6692):    [FF/EDI/run_postcts_hold.tcl]: Invalid return code while executing "FF/EDI/run_postcts_hold.tcl"
    while executing
"setOptMode -fixHoldAllowSetupTnsDegrade TRUE"
    (file "FF/EDI/run_postcts_hold.tcl" line 43)
    invoked from within
"::se_source_orig FF/EDI/run_postcts_hold.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel [concat ::se_source_orig $args]"
    (procedure "source" line 45)
    invoked from within
"source FF/EDI/run_postcts_hold.tcl"
    (in namespace inscope "::" script line 1)
    invoked from within
"namespace inscope :: source $initFile"
Any idea how to remove this error?
  • wally1
    wally1 over 13 years ago
     Try adding the following to your setup.tcl or edi_config.tcl file:
     set vars(fix_hold_allow_tns_degradation) false
     - Brian
  • wally1
    FYI - There is a bug in EDI 11 USR3 and later where "setOptMode -fixHoldAllowSetupTnsDegrade" only accepts lowercase true/false. The Foundation Flow wizard uses uppercase TRUE/FALSE in the setup.tcl and edi_config.tcl files so this error occurs. The workaround is to explicitly set it to lowercase true/false in the setup.tcl or edi_config.tcl file. This problem seems specific to this option. CCR 1109285 has been filed to correct this.
    Brian
