  3. rerun a certain step in foundation flow..?
  • Subscribers 94
  • Views 15188
Arslan
Arslan over 13 years ago
hi, suppose if I already had run make postroute , can i re run it again in the same directory with certain paramaters changed?
-Arslan
  • wally1
    wally1 over 13 years ago
    Hi Arslan,
    You can remove the file make/postroute then run "make postroute". You may need to use the pre_postroute plugin to define the necessary parameters if they are not specific to the postroute step.
    Brian
