  3. edi 11.1 Failed to read Netlist
  • Subscribers 94
  • Views 16276
Vi Muthukumar
Vi Muthukumar over 13 years ago
Dear sir/madam,
I am now using cadence encounter (EDI) 11.1. in the IMPORT Design i am now select the netlist file and also apply the mmmc config file, and i was also apply power nets and lef (all.lef) files. finally i will click ok the tool shows the error
ERROR (ENCVL-902): Failed to read Netlist filename.v please give me the solutions for this problem
THANKS & REGARDS,
M.Muthukumar.
  • Kari
    Kari over 13 years ago
    this usually means that the file didn't exist, or there was a syntax error. Look in the log file for more details about what went wrong.
  • Vi Muthukumar
                       my problem was solved, because during synthesis command, i apply only synthesize.
    now i am apply the correct command synthesize -to_mapped -effort medium . now the import design accept the Netlist file. the tool working fine.
     please tell me anyone this solution is correct or not.
    Thanks & Regards,
    M.Muthukumar.
  • Kari
    i know very little about synthesis, but i think you're in the right ballpark. :-) i just checked a script i have access to, and there's a synthesize -to_generic first, then later a couple of synthesize -to_mapped with various options. so it's probably highly dependent on your flow and what your goals are.
    maybe a synth expert can comment.
