  3. Set default load in Library generation
  • Subscribers 94
  • Views 14456
GreenGraphene
GreenGraphene over 13 years ago
I am creating Standard Cell library. I have generated my own library file. I havent included LEF in the RTL compiler.
1 )When i estimate power my RTL compiler uses a a load I am unaware of . Is is possible for me to generate library file which defines a default load to all pins unless stated ?
2) I chk with command lista and also tried generating scripts for the existing library to see if such option is avaiblable but it went in vain. I want to set a default output pin capacitance that my RTL compiler would follow. Is it possible. ?
