  3. problems with report_timing when using user defined path...
  • Subscribers 94
  • Views 14602
problems with report_timing when using user defined path groups
malicad
malicad over 13 years ago
I am using the following options in report_timing in ETS 12.0.
set_global timing_report_group_based_mode true
report_timing -max_paths 50 -nworst 10
The documentation says it will print the WNS paths for each path group. It does correctly for the first user defined path group but does not for others.
 For example if I have two path groups: grp1 and grp2 with WNS -0.5 and -0.4. The paths in grp2 with WNS -0.4  are not printed.
However if I do,
report_timing -max_paths 50 -path_group grp2, It does print those paths.
Mali
