  3. ui_timingcon_file
  • Subscribers 94
  • Views 15385
ui_timingcon_file
ErezBS
ErezBS over 13 years ago
What is te difference between rda_Input(ui_timingcon_file) and rda_Input(ui_timingcon_file,full) in encounter config file?
thanks!
  • BobD
    BobD over 13 years ago
    This has tripped me up in the past as well. When you set these variables in the GUI it's more clear which is which.
    The ",full" option is for ILMs. The rda_Input(ui_timingcon_file) is what you'd use if you're not using ILMs.
    These notions are present when we go to using MMMC to configure the timing information as well.
    Hope this helps,
    Bob
  • ErezBS
    Hi thanks a lot!
    yes - it helped.
    one more thing - i should define the ",full" with pointers to top level sdc file  and ILM's sdc files?
    Erez.
  • BobD
    If you want to include SDCs that target entities within the ILMs, but written from a top-level context, include them in the ,full.
    If you want to write them in the context of the block-level, include them as part of the ILM definition itself.
    Hope this makes sense.
    -Bob
