  3. Transmission_Gate(TGX1) LIB Generation using Encounter Library...
  • Subscribers 94
  • Views 758
Transmission_Gate(TGX1) LIB Generation using Encounter Library Characterizer ELC Problem
Hatkar
Hatkar over 13 years ago
My TGX1 is Tristate Gate and Not Bidirectional Tristate Gate, Gate file Generated is as follows
DESIGN ( TGX1 );
    //     PORT DEFINITION
        INPUT NG ( NG );
        INPUT PG ( PG );
        INOUT D ( D );
        INOUT S ( S );
        SUPPLY0 GND ( GND );
        SUPPLY1 VDD ( VDD );
        -COMPLEMENTARY ( NG, PG );
    //     INSTANCES
        CMOSX ( S, D, NG, PG );
    END_OF_DESIGN;
CMOS is a Tristate Gate and CMOSX is Bidirectional Tristate Gate.
CMOSX has to be replaced with Primitive or Tirstate Gates according to ECL User Guide
After Replacing  CMOSX, Gate File is as follows
DESIGN ( TGX1 );
    //     PORT DEFINITION
        INPUT NG ( NG );
        INPUT PG ( PG );
        INPUT D ( D );
        OUTPUT S ( S, NG, PG );
    //     INSTANCES
        CMOS ( S, D, NG, PG );
    END_OF_DESIGN;
Generated 8 vectors, Total Simulation Passed 8 (100.00%), generated *.alf, *.lib and *.v file successfully.
*.v verilog file generated is as follows
     module TGX1 (D, NG, PG, S);
            input    D, NG, PG;
            output    S;
            bufif1 (S, D, NG);
     endmodule
I think instead of BUFIF1 (S, D, NG) it should infer CMOS ( S, D, NG, PG).
Please let me know whether whether my above verilog file is correct for TGX1,
if not suggest me any alternative to replace the Bidirectional Switch CMOSX in Gate File, so that generated verilog code will have CMOS Tristate Gate and the code will be as follows
            input    D, NG, PG;
            output    S;
cmos ( S, D, NG, PG);
     endmodule
