  3. Routing of Power Pins of IO pad Pins
  • Subscribers 92
  • Views 13555
amythpai
amythpai over 12 years ago
I want to route the power pins of IO pads like the vdd, gnd, A0SRC and all. I have run the global net connect command :
globalNetConnect VDD -type pgpin -pin {vdd} -inst * -module {}
globalNetConnect GND -type pgpin -pin {gnd} -inst * -module {}
I then tried to route using sroute to route the pins but the metal layer used is thicker than the IO filler cells I have used. Can someone please suggest me te correct way to route the power pins?
