  3. Rail analysis
  • Subscribers 94
  • Views 14721
Rail analysis
kasyab
kasyab over 13 years ago
  I am trying to set up rail analysis under different conditions (min,max, different levels of activity etc.). In order to be able to analyze results at a later time I would like to utilize a separate state directory each time I run RA. I could not find any switch to go with the set_rail_analysis_mode command to enable this. I see a -work_directory_name switch but I assume this chooses the name for the working directory for each run ('work' in the default 'FE2VSEarlyRA/' directory).
 Is there a way to specify an entirely different state directory rather than the default  FE2VSEarlyRA?
Kasyab
