  3. IC5141 CDL in skipping passive devices
  • Subscribers 96
  • Views 16018
lcaley
lcaley over 13 years ago
Hello everyone,
 I'm trying to import a CDL netlist that contains IO pads and logic into IC5141. The issue I am having is that it skips all of the passive devices within the cell. This particular cell has 3 active MOS devices, 3 diodes, and a resistor. CDL in appears to run correctly, but upon checking the schematic, only the 3 transistors are present. Below is the appropriate snippet of the CDL file, my Device Map file, and my ni.log file. I cannot see any reason for the import process to be skipping the passive devices. Please let me know if any additional information or details are needed.
Thank you!
 P.S. I couldn't find a way to enclose the text in a code box, so please excuse the wall of text.
-----------------CDL FILE----------------------
.SUBCKT IDDBREAK VDD VSS VSSIO
*.PININFO VDD:B VSS:B VSSIO:B
RR0 VSS net40 169.876K $SUB=VDD $[RNPPO_SP] $W=500n $L=204.91u
MNM4 VDD net40 net49 VSS NA W=40e-6 L=120n M=4
MNM0 VSS VSS VDD net49 NA W=40e-6 L=120n M=12
DD2 VSSIO VSS DP 2e-11 4.2e-05 M=5
DD0 VSS VSSIO DP 2e-11 4.2e-05 M=5
DD1 VSS VDD DP 2e-11 4.2e-05 M=5
MPM0 VDD net40 VDD VDD PR W=3e-6 L=4u M=12
.ENDS
-------------------DEVICE MAP FILE-------------------------------
devMap := nfet N_11_SPHVT
propMatch := subtype NH
devMap := pfet P_11_SPHVT
propMatch := subtype PH
devMap := nfet N_25_SP
propMatch := subtype NR
devMap := pfet P_25_SP
propMatch := subtype PR
devMap := nfet N_11_SPRVT
propMatch := subtype NA
devMap := pfet P_11_SPRVT
propMatch := subtype PA
devMap := diode DIOP_SP
propMatch := subtype DP
devMap := diode DION_SP
propMatch := subtype DN
-----------------ni.log--------------------------
Subckt: IDDBREAK
Created the CV IDDBREAK->netlist_tmp.
MOS Instance: MPM0
...Searching for a valid mapping in the dev-map file...
        ...Bingo! Cell mapped to P_25_SP->symbol.
Now, searching for the cellview P_25_SP->symbol in ref libs...
    ...in umc65sp: Bingo! Found the master cellview: P_25_SP->symbol.
instName->'MPM0' is created.
propName->'subtype'; propVal->'PR' is created.
propName->'w'; propVal->'3E-06' is created.
propName->'l'; propVal->'4E-06' is created.
propName->'m'; propVal->'12' is created.
'D' mapped to 'D'.
The net 'VDD' of instance 'MPM0' has been connected to the terminal 'D'.
'G' mapped to 'G'.
The net 'net40' of instance 'MPM0' has been connected to the terminal 'G'.
'S' mapped to 'S'.
The net 'VDD' of instance 'MPM0' has been connected to the terminal 'S'.
'B' mapped to 'B'.
The net 'VDD' of instance 'MPM0' has been connected to the terminal 'B'.
MOS Instance: MNM0
        ...Bingo! Cell mapped to N_11_SPRVT->symbol.
Now, searching for the cellview N_11_SPRVT->symbol in ref libs...
    ...in umc65sp: Bingo! Found the master cellview: N_11_SPRVT->symbol.
instName->'MNM0' is created.
propName->'subtype'; propVal->'NA' is created.
propName->'w'; propVal->'4E-05' is created.
propName->'l'; propVal->'1.2E-07' is created.
'D' mapped to 'D'.
The net 'VSS' of instance 'MNM0' has been connected to the terminal 'D'.
'G' mapped to 'G'.
The net 'VSS' of instance 'MNM0' has been connected to the terminal 'G'.
'S' mapped to 'S'.
The net 'VDD' of instance 'MNM0' has been connected to the terminal 'S'.
'B' mapped to 'B'.
The net 'net49' of instance 'MNM0' has been connected to the terminal 'B'.
MOS Instance: MNM4
instName->'MNM4' is created.
propName->'m'; propVal->'4' is created.
'D' mapped to 'D'.
The net 'VDD' of instance 'MNM4' has been connected to the terminal 'D'.
'G' mapped to 'G'.
The net 'net40' of instance 'MNM4' has been connected to the terminal 'G'.
'S' mapped to 'S'.
The net 'net49' of instance 'MNM4' has been connected to the terminal 'S'.
'B' mapped to 'B'.
The net 'VSS' of instance 'MNM4' has been connected to the terminal 'B'.
INFO (CDLIN-54): CDL In successfully created the schematic view IO_lib_SP_2_5V_Inline_Reg_VT.IDDBREAK::netlist. Read the log file
'conn2sch_IDDBREAK.log' for more information.
  • navi2582
    navi2582 over 13 years ago
     I think you may have to include the following at the beginning of your cdl netlist:
    .PARAM
    *.BIPOLAR
    *.RESI = 1
    *.RESVAL
    *.CAPVAL
    *.DIOPERI
    *.DIOAREA
    *.SCALE METER
  • csst
    csst over 12 years ago
    You should also add the resistor in map file
    devMap  := phyres RNPPO_SP
    termMap := PLUS PLUS MINUS MINUS SUB B
