  3. antenna diodes in LEC
  • Subscribers 94
  • Views 15198
kienu
kienu over 13 years ago
I am presently seeing antenna diodes in the umapped points(unreachable points) of the revised netllist. How can i do away with these?
thanks
kiran
  • tstark
    tstark over 13 years ago
    Unreachable points are points that don't reach an output pin and therefore don't affect a primary output logically. It appears the diodes don't matter in the functional compare of your design and can be ignored.
    I presume the design has no non-equivalents related to diodes.
    That is probably the best way do the compare. One option is to write out a netlist without them. Another option is to use the LEC remove command but that has a certain danger to it.
    -ts
