  3. How to get the loading capacitance of a certain instance...
  • Subscribers 94
  • Views 17788
How to get the loading capacitance of a certain instance by encounter?
qijianfei
qijianfei over 13 years ago
 Dear All,
 If I know the instant name and its output pin's name. How can I use encounter to get the loading capacitance of that pin? Which command should I use?
qijianfei
  • BobD
    BobD over 13 years ago
    Here's an example:
    report_property [get_nets [get_property [get_pins DTMF_INST/TDSP_CORE_INST/TDSP_CORE_GLUE_INST/i_962/Y] net_name]]
    total_capacitance_max_fall          | 0.006
    total_capacitance_max_rise          | 0.006
    total_capacitance_min_fall          | 0.006
    total_capacitance_min_rise          | 0.006
    wire_capacitance_max                | 0.002
    wire_capacitance_max_fall           | 0.002
    wire_capacitance_max_rise           | 0.002
    wire_capacitance_min                | 0.002
    wire_capacitance_min_fall           | 0.002
    wire_capacitance_min_rise           | 0.002
    You can query individual values with get_property which should also accept specification of a -view:
    get_property -view default_analysis_view_hold [get_nets [get_property [get_pins DTMF_INST/TDSP_CORE_INST/TDSP_CORE_GLUE_INST/i_962/Y] net_name]] wire_capacitance_max
    Hope this helps,
    Bob
  • qijianfei
    Does this net capacitance include the input capacitances (gate capacitances) of the input pins connected with this output pin?
    Thank you so much Bob.
  • BobD
    I believe total_capacitance does include input pin cap(s), wire capacitance does not.
