  3. problem with sense amplifier detection in ELC
  • Subscribers 94
  • Views 14345
Arslan
Arslan over 13 years ago
hi all, I am trying to generate .lib for the standard configuration of sense amplifier using encounter library characterizer. but following error appears after db_prepare -f commnad:
      DESIGN : CHAPPEL_CKT
- analog node : NMOS_DRAIN
- removed pull-up transistor (1) from VOUT_RIGHT
- loop node ( VOUT_LEFT ) is found
=> no simulation
  stimulus generation  summary
Name        #MOS    #DVEC    #RVEC
CHAPPEL_CKT    5    0    0    *
            0    0
 Reading setup file : /home/opensilicon/demo2/demo_jun11_2/demo/setup.setup
[ERROR(db_prepare)] can not match default LOAD for PIN : $DEFAULT_PINS$
Any suggestions?
