  3. Encounter ENCDB-1256
  • Subscribers 93
  • Views 6166
benao
benao over 13 years ago
 Encounter generates an error.
description man:
NAME
       ENCDB-1256
SYNOPSIS
       Power  pin  %s of instance %s is connected to non-p/g net %s.  Mark the
       net as power net and create associated snet.
DESCRIPTION
       There are no further details for this message
 Can I get more information?
  • benao
     version Encounter: EDI13.10.000
  • wally1
    wally1 over 13 years ago
    The message means there is a pin in the LEF defined with USE POWER or USE GROUND that it connected logically to a signal net. Power/Ground pins can only be connected to special nets that are defined as power/ground during init_design. Make sure this net is defined as a power/ground net during init_design using:
         set init_pwr_net {netName}
         set init_gnd_net {netName}
    Brian
