  3. create power and ground pins
  • Subscribers 94
  • Views 18985
dinac123
dinac123 over 13 years ago
I want create Power and ground pins at various locations in a partioned block.
I succeded in creating "physical pins" by using option -create_pin 1 in addStripe.
But how do I convert these "Physical Pins" object type to a normal IO Pins (add them to the netlist as IO pins).
 Thanks for your replies....
  • BobD
    BobD over 13 years ago
    A new-ish command called "createPGPin" was created to do this. Do you see that available in the version you're using?
    Hope so...
  • dinac123
    Thanks for your reply. Using version 9.13.  Yes, using createPGPin creates a Pin of type IO (and creates only one)
    I wanted to create multiple PG Pin at each location of the 'physical pin' ?
    but I think 'lefOut -stripePin' option would do this job. And use this lef each time when one works on the TOP.
