  3. analyze_early_rail - ERROR: (ENCPARA-1132)
  • Subscribers 94
  • Views 586
Yemelya
Yemelya over 13 years ago
When running analyze_early_rail for ""vss" It works well, but for some reason does not work for VBAT.
"analyze_early_rail -method static -type net_based -bias_voltage 1.55 -net_voltage 1.1 -volt_limit 0.9 -total_current 20 -pad_location_file { {mosquito_afe_vbat.pp vbat} } -display_IR -net vbat"
I got errors which I do not understand:
**ERROR: (ENCPARA-1132): Expected power is not factored into rail analysis and the total power from the instance power file is 0.
**ERROR: (ENCPARA-1190): The area of blocks > core area of the chip.
