  3. PnR tips, macros placement
  • Subscribers 95
  • Views 16896
vincentcold
vincentcold over 12 years ago
Hi !
      I'm new to floorplanning, and PnR in industry level. Can someone please help me with some tips from your experience, and where to find useful examples for macros placement, some kind of things you do to prevent congestion, and make your design more robust. Thanks a lot !
  • fitz
    fitz over 12 years ago
    Unfortunately the answer is "It depends".
    If you are intimate with the circuit you should be able to anticipate the module guide and hence the macro placement based on your knowledge of the data flow.
    If the circuit is completely foreign,  you have a lot of research ahead of you.
    Just to get a plausible start point I generally begin with the EDI automatic floorplan commands planDesign , setPlanDesignMode  and multiPlanDesign.
    Good documentation under  / doc / soceUG / Creating An Initial Floorplan Using Automatic Floorplan Synthesis.html.
    You will notice that planDesign generally places macros toward the periphery, a valid technique because it leaves the central core area free for standard cells.
    If you have hundreds of macros you are going to need the relative floorplan menu "define array constraints"  to simplify your macro positioning.
    The overall strategy  also depends on how many routing layers you have to get over top the macros, if you are forced to go around, congestion is going to be problem.
    The fewer the number of routing layers the closer to the edge they belong.
    With 8-10 interconnect layers your options open up,  IF the macro connected standard cells naturally gravitate toward the center the associated macro  can also be drawn closer to the center .
    It Is going to take time to get right.
    Another trick of the trade is to use trialRoute -noDetour  during your floor planning exercise, if you can solve the congestion problem with low effort routing the final route is going to be easy.
    Shawn
  • vincentcold
    Thank you so much Shawn ! you're awesome. Those tips are really helpful, I have tried them out and I start to get the hang of it. I just needed something to start with.
  • Kari
    Kari over 12 years ago
    I agree, that was an excellent post! Thanks for contributing to the forums, Shawn! :-)
  • Kirtesh Tiwari
    Kirtesh Tiwari over 12 years ago
    lovely , awesome :-) Shawn
