  3. Fixing Transition violations
  • Subscribers 95
  • Views 17149
dinac123
dinac123 over 13 years ago
1. I was trying to fix transition violation using -drv, for  a design with fences and guides. But I was in wain.  Once I removed them
and recreated the encounter database with DEF, and V. The encounter was able to fix them.
2. I removed the fences and groups using encounter (from floorplan menu) and saved the database. But some thing was blocking it to fix the transisition. The '.tran" file read something to do with "setDoAssign" ?
But go through the flow, I had to again, exit and recreate the database.
Did any one experience such a thing.  What I am doing wrong here.
Thanks a lot in advance for your help !!
  • fitz
    fitz over 13 years ago
    Regions and fences can really restrict optDesigns options so my default is generally placeDesign > unplaceAllGuides > optDesign.
    You might also need to add setOptMode -bufferAssignNets true.
    Shawn
  • Kari
    Kari over 13 years ago
    assign statements need to be removed before optimization
    setDoAssign -buffer buf_name on
