  3. How to eradicate a net completely
  • Subscribers 93
  • Views 16284
AThomasL
AThomasL over 12 years ago
I am writing some commands to delete nets and connect their instTerms to other nets.  deleteNet does not always delete the net and its wires.  If the net is connected to a top level port I know to use deleteModulePort - first, but if the net was connected to a lower level port in the original netlist hierarchy, how do I trace through hInst/hNet/hTerm to really delete the net and its possible hierarchical port connections?  Some of my nets are busses and I'll be deleting all members of that bus.  I did figure out that editDelete -net will at least get rid of my wires, but the verification guys don't like when I write a flat Verilog netlist that has wire statements for nets that no longer exist and connect to nothing.
  • AThomasL
    set net [dbGet top.nets {.name == "my_net_to_delete"}]
    array unset busTerms
    foreach hNet [dbGet -e $net.hNets] {
          foreach hTerm [dbGet -e $hNet.hTerms] {
             set hInstName [dbGet $hTerm.hInst.name]
             if {"$hInstName" == "{}" } {
                set hInstName "-"
             set bus [dbGet $hTerm.term.bus]
             if {$bus} {
                set busTerms($hInstName\ [dbGet $bus.basename]) 1
             } else {
                deleteModulePort $hInstName [dbGet $hTerm.term.name]
    foreach bus [array names busTerms] {
       lassign $bus inst port
       deleteModulePort $inst $port
       set bus [dbGet $net.bus]
       if {$bus} {
          deleteNet $bus.baseName
       } else {
          deleteNet $bus
    This has the caveat of deleting whole buses, but you shouldn't be deleting just one net of a bus anyway.  I still have cases of some nets which are hanging around, but they don't have hInst connections.  They have names like a/b/c[0] but are not part of busses (dbGet $net.bus = 0x0).  It's a different issue.  More debugging...
  • AThomasL
    Ugh, I give up. Here is an example of a net that just won't go away:
     <CMD> dbGet $net.??
    allTerms: 0x0
    avoidDetour: 0
    bottomPreferredLayer: 0x255fa5a0
    box: {2147483.647 2147483.647 -2147483.648 -2147483.648}
    bus: 0x0
    hNets: 0x2abc364cbdc0 0x2abc364cbd30 0x2abc364cbc10
    instTerms: 0x0
    isAnalog: 0
    isCTSClock: 0
    isClock: 0
    isDontTouch: 0
    isExternal: 0
    isFixedBump: 0
    isGnd: 0
    isMixedSignal: 0
    isPatternTrunk: 0
    isPhysOnly: 0
    isPwr: 0
    isPwrOrGnd: 0
    isScanNet: 0
    isTrialRouted: 0
    mask: 0
    numInputTerms: 0
    numOutputTerms: 0
    numTerms: 0
    objType: net
    preferredExtraSpace: 0
    props: 0x2abc3a24d398 0x2abc3a30dd10
    rule: 0x0
    sVias: 0x0
    sWires: 0x0
    shieldNets: 0x0
    siPostRouteRepair: 0
    skipAntennaRepair: 0
    skipRouting: 0
    terms: 0x0
    topPreferredLayer: 0x0
    vias: 0x0
    voltage: 0
    weight: 2
    wires: 0x0
    encounter 94> dbGet $net.hNets.??
    <CMD> dbGet $net.hNets.??
    allTerms: 0x0
    hInstTerms: 0x0
    hTerms: 0x0
    instTerms: 0x0
    isGnd: 0
    isPwrOrGnd: 0
    net: 0x2abc35a7abe0
    objType: hNet
    props: 0x0
    allTerms: 0x0
    hInstTerms: 0x0
    hTerms: 0x0
    instTerms: 0x0
    isGnd: 0
    isPwrOrGnd: 0
    net: 0x2abc35a7abe0
    objType: hNet
    props: 0x0
    allTerms: 0x0
    hInstTerms: 0x0
    hTerms: 0x0
    instTerms: 0x0
    isGnd: 0
    isPwrOrGnd: 0
    net: 0x2abc35a7abe0
    objType: hNet
    props: 0x0
     encounter 95> dbGet $net.props.??
    <CMD> dbGet $net.props.??
    objType: prop
    parent: 0x2abc35a7abe0
    value: 33555632
    valueType: int
    objType: prop
    value: 0x0
    valueType: obj
    encounter 101> deleteNet core/rst_sync/rst_sync*
    <CMD> deleteNet core/rst_sync/rst_sync*
    Deleting net [core/rst_sync/rst_sync[2]]
    Deleting net [core/rst_sync/rst_sync[1]]
    Deleting net [core/rst_sync/rst_sync[0]]
    **WARN: (ENCSYC-298):   Found no net name matching wildcard "core/rst_sync/rst_sync*".
    Processed 0 net(s)
    encounter 102> deleteNet core/rst_sync/rst_sync*
    Processed 0 net(s)
    I can't figure out how to delete these nets/hNets.  deleteNet doesn't do anything.  I guess I don't really mind if there are floating nets in the database, but the verification guys don't like them showing up in the output verilog.  Here are the partial results of saveNetlist:
    #  Generated by:      Cadence Encounter 13.10-p003_1
    #  OS:                Linux x86_64(Host ID mbt02.rsint.net)
    #  Generated on:      Wed Aug  7 15:59:07 2013
    #  Design:            TOP
    #  Command:           saveNetlist -flat -excludeLeafCell -phys temp3.v
    module TOP ();
       // Internal wires
       supply1 VDDIO;
       supply0 UNCONNECTED29;
       supply0 UNCONNECTED30;
       supply1 VDD;
       supply0 VEE;
       supply0 VSS;
       wire \core/rst_n_sync/rst_sync[2] ;
       wire \core/rst_n_sync/rst_sync[1] ;
       wire \core/rst_n_sync/rst_sync[0] ;
       wire \core/rst_sync/rst_sync[2] ;
       wire \core/rst_sync/rst_sync[1] ;
       wire \core/rst_sync/rst_sync[0] ;
    endmodule
  • fitz
    fitz over 12 years ago
    disconnectDanglingPort
    Disconnects dangling nets from ports in the whole design, from the top level to the bottom level.
    BUT may not work on partialy deleted bus structures.
    OR give the verification guys a "blue" pill : )
    Shawn
