  3. Adding fillers
  • Subscribers 95
  • Views 17054
Adding fillers
ErezBS
ErezBS over 13 years ago
Should i run incremental placement/routing after inserting the fillers? (i insert them at the end of  my flow).
 Thanks.
  • fitz
    fitz over 13 years ago
    checkPlace, checkFiller, verifyConnectivity & verifyGeometry  will tell you if you need to redo addfiller, refinePlace and / or routeDesign.
    ( normally you run refinePlace without gap fillers in place )
    If your filler cells are totally benign as far as the routing metals go , you should be fine.
    I have to addFiller before the initial routeDesign because my DeCap filler cells have additional M1 geometries inside the typical M1 power rails.
    Luckily optDesign -postRoute is smart enough to automatically deleteFiller > optimize > addFiller > routeDesign
    Shawn
