  3. VerifyGeometry not parsing all the sub area
  • Subscribers 94
  • Views 15741
AnandThibbaiah
AnandThibbaiah over 13 years ago
Hello Everyone,
I am adding decaps after routing optimization using "addFiller -doDRC false -honorPrerouteAsObs false -cell {}"
After that performing verifyGeometry -error 100000
While doing the above step verifyGeometry is stopping after checking one subarea
<CMD> verifyGeometry -error 1000000
 *** Starting Verify Geometry (MEM: 11229.1) ***
  VERIFY GEOMETRY ...... Starting Verification
  VERIFY GEOMETRY ...... Initializing
  VERIFY GEOMETRY ...... Deleting Existing Violations
  VERIFY GEOMETRY ...... Creating Sub-Areas
                  ...... bin size: 1600
  VERIFY GEOMETRY ...... SubArea : 1 of 1
  VERIFY GEOMETRY ...... Cells          :  0 Viols.
  VERIFY GEOMETRY ...... SameNet        :  0 Viols.
  VERIFY GEOMETRY ...... Wiring         :  0 Viols.
  VERIFY GEOMETRY ...... Antenna        :  0 Viols.
  VERIFY GEOMETRY ...... Sub-Area : 1 complete 0 Viols. 0 Wrngs.
VG: elapsed time: 0.00
Begin Summary ...
  Cells       : 0
  SameNet     : 0
  Wiring      : 0
  Antenna     : 0
  Short       : 0
  Overlap     : 0
End Summary
  Verification Complete : 0 Viols.  0 Wrngs.
**********End: VERIFY GEOMETRY**********
 *** verify geometry (CPU: 0:00:00.2  MEM: 1.0M)
 Can anyone tell me the reason for it ??
  • wally1
    wally1 over 13 years ago
    There is only 1 sub-area it has to check:
         SubArea : 1 of 1
     The bin size of each sub area is 1600.
    - Brian
  • AnandThibbaiah
    Hey Brian,
    Thank you for the reply. The area of the block is more than that actually.
    What i am trying to do is add decaps using "addFiller -doDRC false -honorPrerouteAsObs false <decap_cells>"
    After doing this i check for drc using verifyGeometry -error 100000.
    And after this whereever there are drc issues i remove decaps using "addFiller -cell <decap_cells> -fixDRC"
    But verifyGeometry is not doing the way i expected it to do it.
    Is it by default checking on a specific area ?
    Is there any variable to be set to verify drc over the whole block ?
  • wally1
    Can you explain why you believe it is not checking the whole block? Run getVerifyGeometryMode to see if the -area option is set. Run "setVerifyGeometryMode -reset" to set it to the defaults.
    Brian
