  3. Propagated clock for reg2out
  • Replies 9
  • Subscribers 95
  • Views 21879
Aram Shahinyan
Aram Shahinyan over 13 years ago
Dear Friends,
I'm looking into Solution with ID 11327942. Can't figure out how clock latency 2.5ns is decided for reg2out paths
set_clock_latency 2.5 -rise clk2
 Can you please give me a hint?
Aram
  • fitz
    fitz over 13 years ago
    Aram
    We always referenced ip / op delays relative to a "virtual" clock.
    This virtual clock must track the real clock before and after CTS.
    You can automatically update the virtual clock after CTS with the command update_io_latency.
    I know this whole flow / syntax sucks, but primeTime has been doing it this way since the beginning of time.
    Cadence  set_output_delay supports -reference_pin pin_name syntax which would be perfect IF pt_shell also supported it.
    Shawn
    preCTS ideal .............................................
    create_clock -name LINE_CLK -period 3.236 -waveform { 0 1.618 } [get_ports {i_LINE_CLK}]
    set_clock_transition         0.150 [get_clocks {LINE_CLK}]
    set_clock_uncertainty -setup 0.110 [get_clocks {LINE_CLK}]
    set_clock_latency            2.200 [get_clocks {LINE_CLK}]
    create_clock -name LINE_VIRT_CLK -period 3.236 -waveform { 0 1.618 }
    set_clock_transition         0.150 [get_clocks {LINE_VIRT_CLK}]
    set_clock_uncertainty -setup 0.110 [get_clocks {LINE_VIRT_CLK}]
    set_clock_latency            2.200 [get_clocks {LINE_VIRT_CLK}]
    set_output_delay  1.6 -clock [get_clocks {LINE_VIRT_CLK}]  [get_ports {ov_fltr_y_din[1537]}]
    postCTS propagated & virtual clock updated .............................................
    set_propagated_clock               [get_clocks {LINE_CLK}]
    set_clock_latency -fall 1.99566  [get_clocks {LINE_VIRT_CLK}]
    set_clock_latency -rise 1.97041  [get_clocks {LINE_VIRT_CLK}]
  • Aram Shahinyan
     Hello Shawn,
    Thanks for your responce. This gives an idea how it works, but my question really is how the numbers are calculated.
    Have you looked into Solution ID:11327942 ?
    create_clock -name clk2 -period 2.0 -waveform {0 1.0} [get_ports {CK}]
    set_propagated_clock [get_ports {CK}]
     set_clock_latency 2.5 -rise clk2 <==== To insert clock delay
    So the question really is how 2.5ns is calculated?
    Aram
  • fitz
    Sorry. I did not read Solution ID:11327942 before responding.
    The clock network latency is not calculated, initially it is a  educated guess-timate until CTS is run multiple times and it's results stabilize.
    On subsequent runs the new value becomes an accurate preCTS estimate until the final CTS at which point it becomes the actual measured / reported value.
    set_clock_latency evolves ......  guess > estimate > measured
     Shawn
  • Aram Shahinyan
     Thanks You Shawn,
    In other words I can look into timing report to see the time from clock pin (going through buffers) to the flop and put it as
    clock latency, right?
    Best Regards,
    Aram
  • fitz
    Aram : Bingo
    Normally  I parse the detailed CTS reports for  "Rise Phase Delay".
    The automated "update_io_latency" flow becomes essential as you get into  nodes > 65 nm ......... too many corners to do manually.
    Shawn
  • Aram Shahinyan
     Hello Shawn,
    I have tried to set set vars(update_io_latency) {true} in my foundation flow, but clock latency is still not propagatedin reg2out
    Am I missing anything?
    Aram
  • fitz
    See my first response....................
    We have been doing it this way for so long I forgot  the reason why, but there must be a valid reason to put me through decades of pain .
    If you are doing anything different, like setting the output delay relative to the "actual" clock, sorry you are on your own.
    Shawn
  • Aram Shahinyan
    Hi Shawn,
     Thanks a lot for your help! It worked for me!
    Best Regards,
    Aram
  • sasikg59
    sasikg59 over 8 years ago in reply to fitz
    Hello
    I am facing a problem while using the command update_io_latency
    after i run the command. I used timeDesign to save the reports. But io_latency is not saved in the report folder. Is there anything that I could check to make sure io_latency is updated.
