  3. create placement blockage for instance list
  • Subscribers 95
  • Views 21034
Emil M
Emil M over 13 years ago
Dear all
 Is there any way to specify placement blockage for specific instance list using single blockage layer.
For example if I have 1000 instances (with relative naming conventions) can I create placement blockage for that instances.
Emil
  • fitz
    fitz over 13 years ago
    specifySelectiveBlkgGate
    setPlaceMode -selectiveBlockage
    http://www.cadence.com/Community/blogs/di/archive/2012/03/12/five-minute-tutorial-selective-blockage-in-edi-11.aspx
    Under normal circumstances I find it faster to tell placeDesign where to go with guides and regions.
    Sometimes instructing encounter which areas to avoid can lead to unpredictable results.
    Sort of like stepping on a pile of ... hmm ... Jello, you are never absolutely sure which side it will squirt out.
    Shawn
  • Emil M
    Hello Shawn,
    Thank you for your response. using specifySelectiveBlkgGate command, I can create blockage only for one instance, but I have to create blockage for instance list on same location. Do I need create seperate blockage for every instance?
    Thanks, Emil
  • fitz
    You might have to  specifySelectiveBlkgGate -cell * -inst * first to override any defaults then repetitive unspecifySelectiveBlkgGate -inst <inst> if wildcards do not apply.
    Honestly I have never personally used this command , because I am currently stuck in edi v10 because of vendor 65 nm flow requirements.
    I still strongly suggest you tell placeDesign where to go, rather than where not to go.
    Shawn
    [-help]
    [-cell cellName ]
    [-inst instName ]
    Specifies cells and instances that are forbidden to be placed inside the soft blockage during legalization.
    This command works when setPlaceMode -selectiveBlockage is set to true.
    Parameters
    -cell cellName
        Specifies the cell type name as illegal for soft blockage. You can use wildcards (* or ?) with this parameter.
    -inst instName
        Specifies the instance name as illegal for soft blockage. You can use wildcards (* or ?) with this parameter.
    The following command specifies that cell NR2RLX1 and all instance names that begin with MEMCTLU cannot be moved into soft blockage during legalization.
    unspecifySelectiveBlkgGate -cell NR2RLX1 -inst MEMCTLU*
