  3. Classification of nets in DEF
  • Subscribers 96
  • Views 16818
RobB
RobB over 13 years ago
Can anyone help me understand why there are classifications of NETS, PINS, and SPECIALNETS in DEF?
I am looking at the Cadence 13.14 EDI LEF/DEF Language Reference manual - version 5.8, March 2013.
It shows the following for NETS (and something very similar for PINS and SPECIALNETS) :
 NETS numNets ;
   [+ USE {ANALOG | CLOCK | GROUND | POWER | RESET | SCAN | SIGNAL
             | TIEOFF}]
And it has the following description:
USE {ANALOG | CLOCK | GROUND | POWER | RESET | SCAN | SIGNAL | TIEOFF}
Specifies how the net is used.
Value: Specify one of the following:
ANALOG Used as an analog signal net.
CLOCK Used as a clock net.
GROUND Used as a ground net.
POWER Used as a power net.
RESET Used as a reset net.
SCAN Used as a scan net.
SIGNAL Used as a digital signal net.
TIEOFF Used as a tie-high or tie-low net.
Having these classifications seems like a good idea (and they seem to be mentioned at least as far back as SOC8.1USR3's LEF/DEF Language Reference version 5.7 from June 2009). However, I don't know of any way to set, modify, or query them from within EDI.
Is this possible? Thanks!
  • fitz
    fitz over 13 years ago
     These basic NET attribute classifications are used to differentiate how EDI handles them during each of layout stages , placeDesign , clockDesign,  optDesign and routeDesign.
    The majority of the attributes are handled automatically for you by the standard flow.
    ie. The original create_clock constraint  tags the clk root for you and clockDesign tags the rest of the created tree for you.
    Then optDesign & RouteDesign  know not to disturb the sensitive clock tree placement or routes .
    ANALOG = custom manual route , "setAttribute -net -skip_routing true", to prevent routeDesign from automatically routing the specialNet.
    CLOCK = balanced "H" tree or mesh routing,  clockDesign generally automatically handles multiple clock attributes for you, getAttribute -net <clkNet>
    GROUND = "addRing & addStripe" router .
    POWER "addRing & addStripe" router.
    RESET "bufferTreeSynthesis" to buffer high fanout nets.
    SCAN defIn <top>.scanDef & scanTrace allows placeDesign to ignore and reorder scan chains  .
    SIGNAL <default> standard digital signal net .
    TIEOFF for some technologies  'b1/'b0 cannot attach directly to rails and require additional Pullup or pullDown cells
    The system is fairly straight forward until you step out of the standard flow and do something really funky with vi.
    Shawn
