  3. Tech Lef missing SITE statements ?
  • Subscribers 97
  • Views 19462
marten
marten over 13 years ago
Hi there,
we are usige SoC Encounter 13.13 with stm28lp Designkit. When we try to start floorplanning using:
 floorPlan -site CORE -r 1 "$Utilisation" "$RING_WIDTH" "$RING_WIDTH" "$RING_WIDTH" "$RING_WIDTH"
 Encounter throws: **ERROR: (ENCSYC-993):  Cannot find site 'CORE'
So I checked the Technology Lef from our DesignKit
CadenceTechnoKit_cmos028_6U1x_2U2x_2T8x_LB@4.2.1/LEF/technology.16T.lef
 and found out that there are no SITE Definitions inside. Do I have to add them manually ? Or do we need to request a new Tech Lef from CMP ?
Kind Regards
  • vimalraj
    vimalraj over 13 years ago
     Hai marten
    i hope you can request for a new tech lef with sites
  • marten
     Unfortunatly the support for this special designkit has been stopped. So is there maybe another way ?
     I am a bit confused, because all library LEF-Files reference a site called 'CORE12T'. So why is there no Site defined inside the TECH LEF ?
  • Kari
    Kari over 12 years ago
    SITE definitions are typically in the MACRO LEF along with the macros that use that SITE. However, it's an easy thing to create the SITE definition. See the LEF/DEF Language Reference for the syntax.
  • marten
    marten over 12 years ago
     Thanks Kari!
    We got a new version of the designkit with correct LEF files.
    Cheers,
    Marten
