  3. Connect core ring and Power pads
  • Subscribers 94
  • Views 17335
LintonThiago
LintonThiago over 13 years ago
Hi everyone,
I can't connect the power pads to the core ring. I tried with different  power pads, core ring width and pad cells. Every time I use special route the encounter display this warning:
**WARN: (ENCSR-1256):   Cannot find any CORE class pad pin of net VDD1. Check net list, or change port class in LEF file, or change option to include pin in given range.
Cannot find any AREAIO class pad pin of net VDD1. Check net list, or change port class in LEF file, or change option to include pin in given range.
**WARN: (ENCSR-1256):   Cannot find any CORE class pad pin of net VSS1. Check net list, or change port class in LEF file, or change option to include pin in given range.
Cannot find any AREAIO class pad pin of net VSS1. Check net list, or change port class in LEF file, or change option to include pin in given range.
Does anyone know what could be the problem?
Tks,
  • Kari
    Kari over 13 years ago +1
    Check the LEF of the pin on the pwr/gnd pad you're trying to connect. It should be CLASS CORE: PIN VDD DIRECTION INOUT ; USE POWER ; PORT CLASS CORE ;
  • Kari
        PIN VDD
            DIRECTION INOUT ;
            USE POWER ;
            PORT
            CLASS CORE ;
