  3. How to skip ERROR in cadence encounter13.2
  • Subscribers 93
  • Views 15173
ajay01
ajay01 over 12 years ago
Hi All,
When i am source eco file i am getting ERROR.so its stop due to ERROR occur.
so is there  any command available in encounter so we can skipp ERROR and run full file without stop anywhere??
means whenever  ERROR come then it should skipp and executenext command of that eco file.
  • fitz
    fitz over 12 years ago
    You could try "suppressMessage", but the real question is, Why would you ever want to do this?!
    If you have gone through the trouble of generating a series of interactive eco commands, wouldn't you want to guarantee  they work as expected?
    If you just want to speed up your eco script execution / debugging use the -batchMode
    setEcoMode -reset
    setEcoMode -batchMode true
    ecoCommand
    ecoCommand
    ecoCommand
    ecoCommand
    setEcoMode -batchMode false
    Shawn
  • ajay01
    ajay01 over 11 years ago
     Hi shawn,
    I am getting error because eco of from primetime i am sourcing into encounter.
    And i am setting  in encounter LEQCHECK true so it is getting error for some of the eco.
    So how can i skip those error??
    if i made LEQCHECK false then my LEC is failing.
    Ajay
