  3. Incorrect metal layer for pins after Encounter GDS Expo...
  • Subscribers 94
  • Views 15171
Incorrect metal layer for pins after Encounter GDS Export
Kabal
Kabal over 12 years ago
After I export the GDS in Encounter, and then import it to Virtuoso, I see all metal/other layers represented correctly.
But the metal layers for pin areas around design are not having a proper Drawing level. So I have to go ahead and just correct each pin to have a proper metal layer. What could cause this?
  • Kabal
    ok nevermind. corrected the MAP file. It's just I didnt even expect that manufacturer of kit would have such an obvious mess up in a map file he provided and didnt even look there before.
