  3. trialRoute, error adjacent routing layers with same dir...
  • Subscribers 94
  • Views 16447
trialRoute, error adjacent routing layers with same direction
marten
marten over 12 years ago
 Hi there,
i am using Encounter 13.1 and a STM 28FDSOI kit. Floorplanning and prePlace of the design run smoothly but when I try a timeDesign, trialrout exits with the following error:
**ERROR: (ENCTR-7108):  Two adjacent routing layers M8 and M9 are in the same preferred direction.
trialRoute does not support this design style and will exit.
Where is this problem located ? Is it a LEF isssue, do I need to add another lef file?
 Kind regards
  • Kari
    Kari over 12 years ago
    check your tech LEF (that's the one that defines all the routing layers, widths, spacings, etc.). There will be a direction for each layer. They usually alternate horizontal and vertical. Sounds like your M8 and M9 have the same direction. Change the one that seems out of whack.
  • marten
     Hey Kary, thanks!
    The upper layers (above M8) all had the same direction. Since this is a tech LEF provided by CMP I am wondering why one should do that ?!
    Best regards,
    Marten
  • Kari
    you would have to ask the tech LEF vendor why they did that
  • marten
     Okay since there seems to be no obvious reason for this issue, we will contact the vendor.
     Thanks Kari!
