  3. Syntax V93 VHDL
  • Subscribers 94
  • Views 14698
Syntax V93 VHDL
tonio
tonio over 12 years ago
 Hi there,
I am building an ip, i tested it on Xilinx FPGA is seems works
now i m testing it on virtuoso cadence and give me this 2 errors, someone can help please
1) -------------------------------------
E,MLTDRV (./test.vhdl,17|0): Signal/register 'M_ADDR' has multiple drivers.
The specified signal/register has multiple drivers which can
be active simultaneously. This may lead to signal/register
having undefined/unexpected value and can also result in
difference in simulation and synthesis behavior.
The following parameter present in the default rules file can be used to modify the behavior of this check:
params MLTDRV {ignore_z_drivers="yes|no"}
The default value of this parameter is 'yes'. In this case, if a signal has two drivers with
one of the drivers being 'Z', the tool will allow the signal to have a 'Z' driver and a
violation will not be reported. Alternatively, when this parameter is set to 'no', the 'Z' driver
will be considered invalid and a violation will be reported.
The following example illustrates the occurrence of MLTDRV:
assign sig_a = var_a;
assign sig_a = var_b;
In the above example, 'sig_a' is multiply driven.
Line 17---  M_ADDR :   OUT std_logic_vector(31 DOWNTO 0);
Line 378---M_ADDR <= std_logic_vector(to_unsigned(1, 32))+ u2fpi;
2)-------------------------------------------------------
*E,MLTDRV (./test.vhdl,19|0): Signal/register 'M_RD' has multiple drivers.
line 19 ----- M_RD  : INOUT std_logic;
line 493 --- M_ADDR <= std_logic_vector(to_unsigned(0,32))+u3fpi;
Thank  you so much for your help regards
