  3. Blockage of Cell Error
  • Subscribers 94
  • Views 16846
Kabal
Kabal over 12 years ago
I did connect global power nets to all pins. Then did sroute. Then added the standard cells. And the geometry check gives me this errors, thousands of them:
Blockage of Cell U_BUF2/URAM/ram_reg[413][12]
bbox = (322.540, 1477.810) (322.600, 1478.170)
 I am attaching picture pointing to the error with arrow.  The blue lines you see are M1 VDD! and GND! lines, and I have checked the standard cell layout and confirmed that those power lines correctly overlap the power lines of standard cells.
I am not quite getting why the error checker is not happy and what kind of blockage of cell is it talking about? Whst exactly is blocked?
  • Kabal
    One more thing, those errors are heavily concentrated in the lower left part of my design. Picture is attached.
    But what I do not get is, what exactly is blocked? I have not done any routing yet, just power, and placement of standard cells.
    What is the cause of this problem?
  • Kari
    Kari over 12 years ago
    the errors may seem concentrated in the lower left of the design because you probaby hit the 1000 error limit. you can increase the limit in the verifyGeometry run. however, that photo clearly shows a trialroute. i would not run verGeom on a trailroute, it is not DRC-legal routing.
