  3. Simulation of amplification circuit using ORCAD
  • Subscribers 92
  • Views 14432
Sunny13
Sunny13 over 11 years ago
Hi.
I'm not sure if this is the correct forum. In case its not, please direct me to the direct one.
Problem: I'm trying to simulate the amplication circuit in ORCAD using a AC power source and LM 566.
I'm not able to get the waveform in the simulation window.
I've attached the screenshot of the circuit also.
Could anyone please help me in this.
Sunny
  • oldmouldy
    oldmouldy over 11 years ago
    I suspect that, at least part of the issue is that there is no PSpice model found for the LM566C, hence the "green" DRC marker.
  • Sunny13
    Thanks for the reply.
    Could you please guide me how to correct this since I'm a beginner in this.
    If you require I can provide you the circuit file.
    Regards
    Sunny
