  3. TSMC 65nm GDS Import Problem
  • Subscribers 94
  • Views 17629
M Refaat
M Refaat over 12 years ago
Hi there,
I am using TSMC 65nm GP Standard Cell library in my design. After I finish P&R using encounter and export GDSII file, I am trying to import it to Virtuoso in order to have DRC/LVS using Calibre. The problem is that not all layers are imported, almost all layers used for power rings/routing are not there. I think the problem is the mapping file.
So, I appreciate if any one has a solution for that or have a mapping file that is compatible with this technology.
Best,
  • Kari
    Kari over 12 years ago
    Are you saying the problem is with the mapping file in Encounter? Or the stream map file in Virtuoso? The stream map for virtuoso should have come from the foundry and is usually considered golden. You can create the encounter stream map from that. The format is in the documentation.
  • M Refaat
    Thanks Kari for reply.
    What do you mean by steam map for Encounter?
    What I know is that I use the layermap for virtuoso to import the GDS. But, the issue of unmapped layers made me think that the problem is the mapping file used in Virtuoso.
  • Kari
    When you export GDS from encounter, you need to use an encounter-format stream map. It's not the same format as the stream map for Virtuoso. The Encounter user guide explains the format.
     The virtouso stream map should be good if it came from the foundry.
