  3. Timing constraine problem in synthesis
  • Subscribers 92
  • Views 13960
KUMARJAYA
KUMARJAYA over 11 years ago
i had design a divider and a up/down counter for a section of my project.Input frequency of clock is 50mhz and it is divided by 50(1mhzclock) to clock up/down counter.but after synthesis their exist a timing problem to registers define for up/down counter
timing problem is
THE FOLLOWING SEQUENTIAL CLOCK PIN HAVE NO CLOCK WAVEFORM DRIVING THEM.NO TIMING CONSTRAINE WILL BE DERIVED FOR PATH LEADING TO AND FROM THESE PINS(which is registers define in up/down counter)
so how can i define clock(1mhz) to up/down counter(which is divided from input clock of 50mhz)?
  • grasshopper
    grasshopper over 11 years ago
    Hi Kumarjaya,
     the message seems quite clear in that the flop's clock is undefined and the clock waverform is infered. Sounds like you need a 'create_generate_clock' constraint on the output of your divider circuit
    gh-
