  3. Connecting Global power to Pins of instances
  • Subscribers 95
  • Views 15503
Kabal
Kabal over 12 years ago
Sometimes I noticed when you do operation of connecting global power to pins of instances and then do Check operation it says that power is not connected to some instances.
I am curious is it something normal? Does it mean that specific instances are kind of optimized? Or should I be worried about it?
All my instances have VDD! and GND! power pins, and I defined global VDD! and GND! power. In some designs for example, when I choose that operation and then do the Check, it says nothing. i.e. everything is connected, but on another designs (it actually depends on a code) it gives warning that some pins were not connected.
How does that thing usually work out?
  • Kabal
    Those were basically tieLO/HI pins. I just had to run explicit command for their connection. solved.
  • tshovon123
    tshovon123 over 12 years ago
     Hi Kabal
    would u please specify which command you specified for solving the problem.
    Because i am also facing the same problem
    Tanvir Hasanain Shovon
