  3. WARNING(SPMHNI-184): Device library warning detected.
  • Subscribers 94
  • Views 3461
maberu
maberu over 12 years ago
 I encountered below error, how should this be solved?
#1   WARNING(SPMHNI-184): Device library warning detected.
 WARNING(SPMHNI-198): Problems with device 'PIC16F1829-SOIC20,MICROCHIP TEA'. Pinname 'CCP2/P2A/T1CKI/SD02/T1OSI/OSC1/CLKIN/RA5' is replaced by '$0': 'Pin name is not legal.'. [help]
Mabel
  • oldmouldy
    oldmouldy over 12 years ago
    The Pin Name exceeds the default 31 character naming for Capture <> PCB Editor, check that Capture is set to output greater than the default 31 characters and that the Long Name Size in the board is changed to match. If you still have an issue with the pin name after that, you will need to rename the pin to get this to work correctly. There have been some changes to permitted characters since the Base Release of 16.6, so you might want to get the latest hotfix and try that as well before renaming the pin.
