  3. Using RTL compiler PLE with DEF flow
  • Subscribers 92
  • Views 14155
tompy
tompy over 11 years ago
I would like to adapt DEF flow with RTL compiler PLE.
Is there any user guide or manual I can reference with?
And should I get a detailed DEF from backend or I can just take a rough DEF (only information about memory, hard macro, and some high level hierarchical design)?
thanks!
  • tompy
     By the way, I only have RC200.Do I need other feature to run DEF flow?
  • grasshopper
    grasshopper over 11 years ago
    Hi Tompy,
    I am not sure what you mean by the DEF flow. If, by that, you mean a flow that reads a DEF file, then reading a DEF does not require anything beyond RC200. However, other licenses may be required if you want to enable physical features such as congestion mitigation, etc.
    As per the DEF, indeed a floorplan is what is expected and recommended and not a detailed floorplan. If you have a final floorplan, all cells are fixed and hence there would not be much for the synthesis tool to do
    Please review user guide
    gh-
