  3. Setting Timing Derate
  • Subscribers 95
  • Views 22125
tshovon123
tshovon123 over 12 years ago
 Hi I am shovon
New to encounter. So facing syntax related problem .
How can i apply diffrent derating factors for setup and hold in OCV.
It will be helpful if anyone elaborate about setting different derating factors according to mode and check type for a particular delay corner. That is I want to set different derating factor for different analysis view.
Tanvir Hasnain Shovon
  • kazad
    kazad over 12 years ago
     Hi Tanvir
     Once you create the analysis views (Cadence doc attached), you can use something like this for applying OCV derating:
    ________viewDefinition.tcl________
    #create library sets
    create_library_set -name lib_slow -timing {./slow_test.lib}
    create_library_set -name lib_fast -timing {./fast.lib}
    #create Constraint Modes
    create_constraint_mode -name mode_mission -sdc_files {./default.sdc}
    #create RC Corners
    create_rc_corner -name rc_slow
    create_rc_corner -name rc_fast
    #create Delay Corners
    create_delay_corner -name dc_slow \
    -late_library_set lib_slow \
    -early_library_set lib_fast \
    -late_opcond_library slowlib \
    -early_opcond_library fastlib \
    -late_opcond slow \
    -early_opcond fast
    create_delay_corner -name dc_fast \
    -late_opcond slow \
    -early_opcond fast
    #create analysis views
    create_analysis_view -name view_slow_mission -constraint_mode mode_mission -delay_corner dc_slow
    create_analysis_view -name view_fast_mission -constraint_mode mode_mission -delay_corner dc_fast
    #set current analysis views
    set_analysis_view -setup {view_slow_mission} -hold {view_fast_mission}
    # Apply OCV derating (5% for eaxample)
    set_timing_derate -delay_corner  dc_slow -early 0.95
    set_timing_derate -delay_corner  dc_slow -late 1.00
    set_timing_derate -delay_corner  dc_fast -early 1.00
    set_timing_derate -delay_corner  dc_fast -late 0.95
    Khandaker
    Timing and Mode Setup.v1.pdf
  • tshovon123
    Hi Khandaker,
    But there is a problem . If we execute this command same derating factor is applied for all the views related to this delay corner dc_slow. But I dont expect this.
     I just expect different derating factor for different analysis view. With this command I can not specify different derating factors to setup and hold.
    Thanks for quick reply
    Tanvir
  • kazad
     Hi Tanvir
     In that case, you try the procedure:
     # Usage: applyDerate -view <mmmc_analysis_view_name> -early <early_derate_vaule> -late <late_derate_vaule>
    proc applyDerate {args} {
        # Get analysis view name
        if {[regexp {\-view} $args]} {
     set viewName [lindex $args [expr [lsearch $args -view] + 1]]
        # Get early derate
        if {[regexp {\-early} $args]} {
     set earlyDerate [lindex $args [expr [lsearch $args -early] + 1]]
        # Get late derate
        if {[regexp {\-late} $args]} {
     set lateDerate [lindex $args [expr [lsearch $args -late] + 1]]
        # Help
        set helpString "Usage : applyDerate \
                                    \-view <mmmc_analysis_view_name> \
                                    \-early <early_derate_vaule> \
                                    \-late <late_derate_vaule> \
                                    \-help"
        if {[regexp {\-help} $args] || $args == ""} {
            puts $helpString
            return 0
        # Main code
        # Check analysis view if exists
        if {[findAnalysisView $viewName] == ""} {
     Puts "\nERROR: Analysis view $viewName not found!"
     return 0
        # Apply timing derate
        set delayCorner [get_analysis_view $viewName -delay_corner]
        set_timing_derate -delay_corner $delayCorner -early $earlyDerate
        set_timing_derate -delay_corner $delayCorner -late $lateDerate
    # Procedure to find MMMC analysis view name
    # Usage: findAnalysisView *ideal*
    proc findAnalysisView {viewPattern} {
        set viewList {}
        foreach view [all_analysis_views ] {
     if [string match $viewPattern $view] {
         lappend viewList $view
        return $viewList
    Khandaker
  • tshovon123
     Thanks a lot khandakar .. Now it makes sense
