  3. clock uncertainty
  • Subscribers 94
  • Views 17401
clock uncertainty
iullah
iullah over 12 years ago
Hello All!
How can I define different uncertainty value for different delay corners (i. e WCL_rcworst_-40) in encounter?
  • kazad
    kazad over 12 years ago
     Hi
    Following procedure may help. Basically, you need to provide the SDC file with the new/updated clock uncertainty.
    For examle:
     updateSDC -view WCL_rcworst_-40 -sdc <sdc_file_with_new_clock_uncertainty>
    # Procedure to update MMMC constraints
    # Usage: updateSDC -view <all | view_name> -sdc <sdc_file>
    proc updateSDC {args} {
        # Default
        set view "all"
        # Get mode name
        if {[regexp {\-view} $args]} {
            set view [lindex $args [expr [lsearch $args -view] + 1]]
        # Get SDC file name
        if {[regexp {\-sdc} $args]} {
            set newSdcFile [lindex $args [expr [lsearch $args -sdc] + 1]]
        # Help
        set helpString "Usage : updateSDC -view <all | view_name> \
                                      \-sdc <sdc_file> \
                                      \-help"
        if {[regexp {\-help} $args] || $args == ""} {
     puts $helpString
     return 0
        # Main code
        # Save existing setup/hold views
        set restore [get_global timing_defer_mmmc_object_updates]
        set active_setup_views [all_setup_analysis_views]
        set active_hold_views [all_hold_analysis_views]
        set_global timing_defer_mmmc_object_updates true
        if {$view == "all"} {
     # For all views
     foreach view [all_analysis_views] {
         # Check if same file exists; replace if exists
         # otherwise, append it
         set modeName [get_analysis_view $view -constraint_mode]
         set sdcFiles [get_constraint_mode $modeName -sdc_files]
         set loc [lsearch -exact $sdcFiles $newSdcFile]
         if {$loc >= 0} {
      set sdcFiles [lreplace $sdcFiles $loc $loc]
         } else {
      lappend sdcFiles $newSdcFile
         # Update
         update_constraint_mode \
      -name $modeName \
      -sdc_files $sdcFiles
        } else {
     # For specific view
     if {$loc >= 0} {
     } else {
     # Update
         -name $modeName \
        set_analysis_view -setup $active_setup_views -hold $active_hold_views -update_timing
        set_global timing_defer_mmmc_object_updates $restore
  • iullah
    Thanks a lot Mr. kazad for your detailed explanation. I am going to check it.
