  3. SoC Encounter - Timing Report Confusion
  • Subscribers 95
  • Views 2215
shayansh
shayansh over 12 years ago
I'm sorry if this is a basic question, I am new to using encounter.
During synthesis, i set constraints on the clock like clock_latency and uncertainty to synthesize assuming a pessimistic clock distribution. Based on my understanding these parameters make sure to create a pessimistic setting in synthesis to make sure the design meets timing. I understand these so far and mostly how they affect the synthesis and the design.
My main question is, once I move on to place and route in encounter. I feed the synthesized netlist and a *.sdc file which includes all these constraints to encounter for place and route. I am able to place and route everything and see my timing reports. BUT it seems that the timing reports, STILL use these constraints from synthesis. I feel like they shouldn't anymore, since the clock tree has already been synthesized in encounter, the tool should just use that for timing, and not rely on settings I had in synthesis. I was wondering if I need to set anything special in encounter to make sure that the timing reports reflect the synthesized clock tree and not the constraints I set in synthesis of the RTL.
Any feedback anyone can give me would be appreciated.
  • fitz
    fitz over 12 years ago
    Generally we use two values for set_clock_uncertainty -setup,
    - slightly pessimistic values for synthesis , tuned by layout feedback.
    - the actual hard target for the layout & signoff tools.
    You are correct the intent of the pessimism is to leave  "A get out of jail free card" for layout.
    Also you can pull a  similar trick within encounter by dynamically modifing the signoff uncertainty with the setOptMode -setupTargetSlack option.
    ie. preSCTS +100ps , postCTS +50ps and  postRoute +10ps
    set_clock_latency is an estimate for synthesis but once CTS is run this value is automatically updated  with clockDesign -updateIoLatency option.
    Shawn
  • shayansh
     Thanks for the feedback Shawn!
