  3. Regarding more DRCs at routing for 28nm designs using routeDesign...
  • Subscribers 94
  • Views 15084
Regarding more DRCs at routing for 28nm designs using routeDesign command using encan advanced license
MGREDDY
MGREDDY over 12 years ago
Iam working on 28nm design using soc encounter with the following steps,
Placement -> prectsopt -> CTS -> postcts_opt for setup and hold -. routing -> postroute opt
1)Iam using padding for the flops at placement stage.
2) CTS done by using the CellHalo for clock buffers,
3) Routing is done using routeDesign command
Here, at routing stage Iam getting lot of DRCs around #6000 while routing the design, but when I do verifyGeometry with the default options Iam getting around 1000 DRCs. confusion with this number.
"routeDesign shows different DRC count than VerifyGeometry"
Iam using the following nanorouting settings for routing the design.
 setNanoRouteMode -routeWithViaOnlyForStandardCellPin 1:2
setNanoRouteMode -routeWithViaInPin false
setNanoRouteMode -routeUseMultiCutViaEffort medium
 setNanoRouteMode -drouteAutoStop false
routeDesign
Please give me suggestions/advises inorder to reduce the number of DRC count at routeDesign.
Is any switch should be added while routing the design with setNanoRoueMode?
FYI Iam using EDI 11.13V tool.
Thank you,
Waiting for response.
  • Kari
    Kari over 12 years ago
    you have to look at the violations and figure out what's going on so you can fix it.
