  3. Adding Routing blockage around boundary of block
  • Subscribers 95
  • Views 19925
NaikGangadhar
NaikGangadhar over 12 years ago
Hi All,
I would like share the the script to create the routing blockage around the boundary of block.
 Note :
1) This is technology specific script.
2) You have edit the metal layer name as per your requirement.
Proc is as follows :
 proc createRouteBlkBoundray {width} {
## Create rectilinear floorplan shape
set fplanPolygon [dbShape -output polygon [dbGet top.fplan.boxes]]
# Create routing blockage around inside of block boundary with width $blkgWidth
set blkgWidth $width
set sizeValue [expr 0 - $blkgWidth]
set shrunkBox [dbShape $fplanPolygon SIZE $sizeValue]
set donut [dbShape $fplanPolygon ANDNOT $shrunkBox]
      foreach rect $donut {
   set xl [lindex $rect 0]
   set yl [lindex $rect 1]
   set xu [lindex $rect 2]
   set yu [lindex $rect 3]
   if [ expr $xl > $xu ] {
    set xdiff [expr $xl - $xu]
   } else {
    set xdiff [expr $xu - $xl]
   if [ expr $yl > $yu ] {
    set ydiff [expr $yl - $yu]
   } else {
    set ydiff [expr $yu - $yl]
   if {[ expr $xdiff - $width] == "0" } {
    #set layer "vertical"
               #  -layer needs to change as per your technology or as per your requirement
    createRouteBlk -box $rect -layer {M3 M5}
   } else {
    #set layer "horizonal"
    createRouteBlk -box $rect -layer {M1 M2 M4 M6}
Usage is as follows :
 #createRouteBlkBoundray <width in um>
In case of 0.5 micron, type below
 createRouteBlkBoundray 0.5
Gangadhar Naik
  • Jfiedler
    Jfiedler over 5 years ago
    I'm assuming this is in TLC?
