  3. ncvhdl compilation error
  • Subscribers 93
  • Views 15422
livid
livid over 12 years ago
Hello
I am trying to compile a top level design. This top level design contains sub-blocks.
All the sub-blocks apart from one are compiled into the default directory, WORK.
One sub-block is compiled in a different directory, WORK_ECU
The configuration is defined as follows:
library work;
library work_ecu;
-- entity name: uccp_block1_mcp_gram_cfg
-- purpose: Universal Communications Core Platform (UCCP) Synthesis/Layout Block 1 configuration
configuration uccp_block1_mcp_gram_cfg of uccp_block1_mcp_gram is
   for rtl
      for all : img2_resetn_ip_sync
         use configuration work.img2_resetn_ip_sync_cfg;
      end for;
      for gen_mcp_rst
         end for;
      end for;
      for all : uccp_sysbus_addr_dec_block1
         use entity work.uccp_sysbus_addr_dec_block1(rtl);
      end for;
      for all : uccp_pbus_addr_dec_block1
         use entity work.uccp_pbus_addr_dec_block1(rtl);
      end for;
      for gen_mcp
         for gen_mcp_i
            for all : mcp_top
               use configuration work.mcp_top_cfg;
            end for;
         end for;
      end for;
      for gen_ecu
         for all : uccp_mips_ecu_wrap
            use configuration work_ecu.uccp_mips_ecu_wrap_cfg;
         end for;
      end for;
I have updated the hdl.var as follows:
INCLUDE $CDS_INST_DIR/tools/inca/files/defaults/hdl.var
DEFINE WORK pvrlib
DEFINE WORK_ECU mips_ecu_lib
DEFINE NCSIMRC ncsimrc
I have updated cds.lib as follows:
SOFTINCLUDE $CDS_INST_DIR/tools/inca/files/cds.lib
DEFINE pvrlib   ./pvrlib
DEFINE mips_mcu_lib ./mips_mcu_lib
DEFINE mips_ecu_lib ./mips_ecu_lib
When I try to compile the code, I get the following error:
cvhdl -v93 -error 5 -nocopy -work pvrlib  ../../src/main/uccp_block1_mcp_gram.vhd
ncvhdl -v93 -error 5 -nocopy -work pvrlib  ../../src/config_cfg0043/uccp_block1_mcp_gram_cfg.vhd
library work_ecu;
ncvhdl_p: *E,LIBNOM (../../src/config_cfg0043/uccp_block1_mcp_gram_cfg.vhd,21|15): logical library name must be mapped to design library [11.2].
ncvhdl_p: *E,IDENTU (../../src/config_cfg0043/uccp_block1_mcp_gram_cfg.vhd,54|37): identifier (WORK_ECU) is not declared [10.3].
make: *** [.vmkr_Linux/uccp_block1_mcp_gram_cfg_uccp_block1_mcp_gram.ana] Error 1
[1] 4261
Exiting with status code 2
Any thoughts or pointers appreciated.
JO
