  3. ELC cannot run db_spice
  • Subscribers 93
  • Views 13621
great  ljx
great ljx over 11 years ago
 hello.
I use ELC to character INV and NAND2,when I type db_spice ,it shows
   DESIGN        PROCESS       #ID         STATUS     IPDB
INVX1          typical       D0000         SIMULATE    foo
INVX1          typical       D0001         SIMULATE    foo
INVX1          typical       2          2            foo
NAND2X1        typical       D0000         SIMULATE    foo
NAND2X1        typical       D0001         SIMULATE    foo
NAND2X1        typical       D0002         SIMULATE    foo
NAND2X1        typical       D0003         SIMULATE    foo
NAND2X1        typical       D0004         SIMULATE    foo
NAND2X1        typical       D0005         SIMULATE    foo
NAND2X1        typical       D0006         SIMULATE    foo
NAND2X1        typical       D0007         SIMULATE    foo
NAND2X1        typical       8          8            foo
 2014-07-23 16:21:58 (2014-07-23 08:21:58 GMT) : Vectors Launched 10/10
               Simulation Summary
   DESIGN    |   PROCESS   |   #ID    |   STAGE    |  STATUS   |    IPDB
INVX1          typical       D0000     SIMULATE     FAIL        foo
INVX1          typical       D0001     SIMULATE     FAIL        foo
NAND2X1        typical       D0000     SIMULATE     FAIL        foo
NAND2X1        typical       D0001     VERIFICATE   PASS        foo
NAND2X1        typical       D0002     SIMULATE     FAIL        foo
NAND2X1        typical       D0003     VERIFICATE   PASS        foo
NAND2X1        typical       D0004     SIMULATE     FAIL        foo
NAND2X1        typical       D0005     VERIFICATE   PASS        foo
NAND2X1        typical       D0006     SIMULATE     FAIL        foo
NAND2X1        typical       D0007     VERIFICATE   PASS        foo
[INFO(db_spice)] Check the encounterlc.log/<ipdb_name>/<DESIGN>_<PROCESS>_<ID>.log file to determine the cause of the failure. The SPICE simulation log file can be found in the /home/IC_design/VLSI/ELC/encounterlc.work/<DESIGN>_<PROCESS>_<ID>/ directory.
 - Total Simulation : 10
 - Total Passed     : 4(40.00%)
 - Total Failed     : 6(60.00%)
and My dut,scs is
simulator lang=spectre
subckt NAND2X1 in1 in2 out vdd gnd
    \+3 (vdd in2 out vdd) tsmc25P w=4.5e-06 l=3e-07 as=2.025e-12 \
        ad=3.375e-12 ps=9e-07 pd=6e-06 m=1 region=sat
    \+2 (out in1 vdd vdd) tsmc25P w=4.5e-06 l=3e-07 as=3.375e-12 \
        ad=2.025e-12 ps=6e-06 pd=9e-07 m=1 region=sat
    \+1 (out in2 _6 gnd) tsmc25N w=2.7e-06 l=3e-07 as=1.215e-12 ad=2.025e-12 \
        ps=9e-07 pd=4.2e-06 m=1 region=sat
    \+0 (_6 in1 gnd gnd) tsmc25N w=2.7e-06 l=3e-07 as=2.025e-12 ad=1.215e-12 \
        ps=4.2e-06 pd=9e-07 m=1 region=sat
ends NAND2X1
subckt INVX1 in out vdd gnd
    \+1 (out in vdd vdd) tsmc25P w=4.5e-06 l=3e-07 as=3.375e-12 \
        ad=3.375e-12 ps=6e-06 pd=6e-06 m=1 region=sat
    \+0 (out in gnd gnd) tsmc25N w=2.7e-06 l=3e-07 as=2.025e-12 ad=2.025e-12 \
        ps=4.2e-06 pd=4.2e-06 m=1 region=sat
ends INVX1
my setup.ss is ~
Process typical {
        Voltage = 2.5;
        temp = 25;
        Corner = "TT";
        Vtn = 0.67;
        Vtp = 0.92;
Process best {
        voltage = 5.5;
        temp = 0;
        Corner = "FF";
        Vtn = 0.63;
        Vtp = 0.89;
Process worst {
        voltage = 4.5;
        temp = 125;
        Corner = "SS";
        Vtn = 0.71;
        Vtp = 0.92;
Signal  std_cell {
        unit = REL;
        Vh = 1.0 1.0;
        Vl = 0.0 0.0;
        Vth = 0.8 0.8;
        Vsh = 0.8 0.8 ;
        Vsl = 0.2 0.2;
        tsmax = 2.0n;
Signal  std_cell_6710 {
        unit = REL ;
        Vh = 1.0 1.0 ;
        Vl = 0.0 0.0 ;
        Vth = 0.3 0.7 0.3 0.7;
        Vsh = 0.8 0.8 ;
        Vsl = 0.2 0.2 ;
        tsmax = 2.0n;
Signal VDD5.0V  {
       unit = ABS ;
       Vh = 5.0 5.0 ;
       Vl = 0.0 0.0 ;
       Vth = 2.5 2.5 ;
       Vsh =  2.0 2.0 ;
       Vsl = 0.5 0.5 ;                         tsmax = 2.0n;
Signal VDD2.5 {
       unit = ABS ;
       Vh  = 2.5 2.5 ;
       Vl = 0.0 0.0 ;
       Vth = 1.25 1.25 ;
       Vsh = 2.0 2.0 ;
       Vsl = 0.5 0.5 ;
       tsmax = 2.0n ;
Simulation std_cell {
           transient = 0.1n 80n 10p ;
           dc = 0.1 4.5 0.1 ;
           bisec = 6.0n 6.0n 100p ;
//           resistance = 10K ;
           resistance = 10MEG;
Index DEFAULT_INDEX {
      Slew = 0.1n 0.3n 0.7n 1.0n 2.0n ;
      Load = 0.025p 0.05p 0.1p 0.3p 0.6p;
Index X1 {
Index X4 {
      Load = 0.1p 0.2p 0.4p 1.2p 2.4p;
Index IO5*5 {
      Slew = 0.1n 0.3n 0.6n 1.3n 3.0n ;
//      Load = 5p 10p 20p 50p 75p;
       Load = 0.05p 0.10p 0.20p 0.50p 0.75p;
Group POWR {
      PIN = *.Vdd *.Vdd2;
Group Core_Pins {
      PIn = *.DO *.DI ;
Group Pad_Pins {
      PIN = *.YPAD;
Group Clk_Slew {
       PIN = *.CLK ;
Group X1 {
      CELL = 8X1;
Margin m0 {
       setup = 1.0 1.0 ;
       hold = 1.0 1.0 ;
       release = 1.0 1.0 ;
       removal = 1.0 0.0 ;
       recovery = 1.0 1.0 ;
       width = 1.0 1.0 ;
       delay = 1.0 1.0 ;
       power = 1.0 0.0 ;
       cap = 1.0 0.0 ;
Norminal n0 {
         delay = 0.5 0.5 ;
         power = 0.5 0.5 ;
         cap = 0.5 0.5 ;
set process (typical ,best , worst ) {
         simulation =std_cell ;
         signal = std_cell_6710;
         margin = m0;
         norminal = n0;
set index (typical ,best , worst ) {
          Group(X1) = X1;
          Group(X4) = X4;
          Group(Pad_Pins) = IO5*5;
          Group(Core_Pins) = X4;
          Group (Clk_Slew) = Clk_Slew ;
set signal (typical ,best ,worst ) {
           Group(POWR) = VDD2.5V ;
can anyone help me solve this , >_<,   thanks
Liu
  • Khenglish
    Khenglish over 11 years ago
    I noticed that your setup file is a direct copy from the Erik Brunvand book.  Since you are using a TSMC process, I'm assuming it is relatively modern, but you are using voltage parameters that correspond to the 600nm MOSIS process that Brunvand was using.  You are calling for threshold voltages that are completely impossible, and supply voltages that would instantly fry the transistors.  Try realisitc values like 1.1V for the supply voltage, and .25V for threshold voltage.
