  3. ELC (Simulation failed with the status 25600)
  • Subscribers 95
  • Views 14785
maple
maple over 12 years ago
 I am trying out ELC and found one issue, db_spice couldn't pass, output looks like below:
elc>  db_spice -s spectre -p typical -keep_log -keep_wave
   DESIGN        PROCESS       #ID         STATUS     IPDB
INVX1          typical       D0000         SIMULATE     foo
INVX1          typical       D0001         SIMULATE     foo
INVX1          typical       2          2            foo
NAND2X1        typical       D0000         SIMULATE     foo
NAND2X1        typical       D0001          PASSED      foo
NAND2X1        typical       D0002         SIMULATE     foo
NAND2X1        typical       D0003          PASSED      foo
NAND2X1        typical       D0004         SIMULATE     foo
NAND2X1        typical       D0005          PASSED      foo
NAND2X1        typical       D0006         SIMULATE     foo
NAND2X1        typical       D0007          PASSED      foo
while encounterlc.log/foo.log/*.log says
 Simulation deck created in /home/eda1/ELC/encounterlc.work/foo.work/INVX1_typical_D0000
Using command spectre
Releasing lock
the corresponding .lis file says:
Aggregate audit (4:34:48 PM, Thur Jul 24, 2014):
Time used: CPU = 1.17 s, elapsed = 1.17 s, util. = 100%.
Time spent in licensing: elapsed = 798 ms, percentage of total = 68.3%.
Peak memory used = 46.8 Mbytes.
spectre completes with 0 errors, 0 warnings, and 0 notices.
Seems simulation passed without an issue.
I am really puzzled, could someday let me know what I should do in order to debug this?
I am using ETS10.1 + MMSIM7.2,  haven't found version compatible information in ELC document either.
 Thanks!
  • aggiestudent
    aggiestudent over 11 years ago
    I'm facing a similar issue when I use ELC. I have the same error status and I have no errors in the spectre log.
    If you have found the solution for this, could you please share it here?
    Thanks.
