  3. Cannot find output terms for clock synthesis
  • Subscribers 92
  • Views 14188
FMRLI
FMRLI over 11 years ago
I am getting an error while doing clock tree synthesis in encounter 10.1. It showing that
**ERROR: (ENCCK-158): Cannot find output terms for clock clk_in/ANAIO.
Here pad inastant name is "clk_in" and pin name is "ANAIO".
Clock tree specification file is
        AutoCTSRootPin clk_in/ANAIO
        NoGating rising               # (for auto CTS on a net)
        Buffer HS65_LS_BFX2 HS65_LS_BFX4 HS65_LS_BFX7 HS65_LS_IVX2 // name of buffer used for CTS
       MaxDelay 5ns
       MinDelay 0ns
       MaxSkew 50ps
       End
  • wally1
    wally1 over 11 years ago
    Is the IO pad defined in the timing library?
    Brian
  • FMRLI
    Thanks for reply,
    Here I just written the .lef text for ANAIO pin, which is a core side pin for the clock signal. CTS runs on the pin-ANAIO direction is "OUTPUT". However, the actual pin direction is "INOUT" from the technology .lef.
    PIN ANAIO
       DIRECTION INOUT ;
       PORT
       CLASS CORE ;
       LAYER M2 ;
        RECT 6.400 110.350 23.200 112.000 ;
      END
      PORT
       LAYER M2 ;
       LAYER AP ;
        RECT 3.000 109.000 37.000 112.000 ;
      END
  • wally1
    I tested this and verified the clock root cannot be an inout pin. I recommend temporarily setting the LEF pin direction to OUTPUT during CTS to workaround this.
    Brian
