  3. Design is tight after placing cells
  • Replies 14
  • Subscribers 94
  • Views 21655
PatriciaG
PatriciaG over 12 years ago
Hello
After placing a design all the cells are concentrated in one place, the tool takes a very long time to finish and after a lot of iterations I have geometry and shorts violations.
I set the Clock to a very low frequency (in ps) hoping to relax the timing constrains in rtl compiler.
Period      5000000
Delay       10000
OutDelay 10000
 I also used :
 modulePadding -uniformDensity true
The utilization is very low as well (0.4)
Also, during routing I got the following warnings from encounter:
#WARNING (NREX-28) The height of the first routing layer M1 is 0.000000. It should be larger than 0.000000
#WARNING (NREX-29) The metal thickness of routing layer M1 is 0.000000. It should be larger than 0.0. Add this to the technology information for better accuracy.
#WARNING (NREX-30) Please also check the height and metal thickness values for the routing layers heigher than routing layer M1
#WARNING (NREX-4) No Extended Cap Table was imported. Not enough process information was provided either and default Extended Cap Table database will be used.
#WARNING (NRAG-41) The M1 user tracks are removed and regenerated from M3
# M1           H   Track-Pitch = 0.200    Line-2-Via Pitch = 0.205
#WARNING (NRAG-44) Track pitch is too small compared with line-2-via pitch
 So I have two questions,
- How can I make sure the cells are spread a better in all the available area?
- For the warnings: To fix it, should i set a parameter in the lef file? if so, which one?
Thanks!
  • Kari
    Kari over 12 years ago
    try turning on the NPref Track (non-preferred direction) for M2. It looks like the M2 is a bit off, and if we can shift it, maybe the vias would line up without violations. at least in the second picture.
  • PatriciaG
    Hello Kari
    I turned on the NPref Tracks and it seems the router follows the tracks in the majority of the cases and goes out of it in other particular cases. Like in the example below where some parts of M3 are on track and others are off track. What do you think? Is there a way to adjust this?
    Thanks!
  • Kari
    Unfortunately at this point, it's hard to tell what's going on without having the design. Going off the tracks is not necessarily a bad thing. Nanoroute will do that if necessary to complete the route. Where did the tech LEF come from? You may need to go back to the source and say you're having trouble getting a clean route. Maybe there is an updated tech LEF available.
  • PatriciaG
    I generated the LEF file from the technology file, and since this is a university project we don't have any support :( I wonder if there is something else that I can try?
