  3. Generated, gated and multiplexed clocks
  • Subscribers 94
  • Views 15168
mkamal
mkamal over 12 years ago
Hi guys,
I implemented a module with multiple clock inputs which I need to synthesize.
say I have clk1_in & clk2_in input to a clock mux. The mux output is clk_mux_out. Then clk_mux_out is gated to generate clk_mux_g.
Do I have to define all these clocks in the synthesis script ?
What I do is define all these clocks, assign them the same domain and clock frequency.
In case I want to make the constraint of one of these clocks tighter than others for as margin is it harmful regarding the clock to clock edge ?
In case I multiplex two clock of different frequencies, do I need to constraint the mux output to the fastest clock ?
