  3. Timing analysis Cadence RTL compiler
  • Subscribers 93
  • Views 14489
kenambo
kenambo over 11 years ago
Hi all
I want to do some post synthesis analysis using Cadence RTL compiler to understand the timing concepts.
While doing this i got into a doubt that is what will happen if i define clock only for the clk port and keep other ports undefined like not setting any input or output external delays.
By doing like the above.. how rtl compiler generates timing report and i saw R and F in the timing report of a synthesized design.
What does this R and F stands for?
thanks.
  • Mr Aseem
    Mr Aseem over 11 years ago
    R and F stands for Rising and Falling edge.
    As  far as I know , we only define one clock port in the synthesis script even though your clock is routed in many registers inside your design.
    We define clock only for the one clock port. I dont know if that answers.
    Best
    Aseem
  • grasshopper
    grasshopper over 10 years ago
    If you do not define a clock or delay, you are leaving for the tool to define, whatever tool you use. I would say that is simply asking for trouble so I would define all the I/O hence not needing to wonder what each tool may do
    just my 2c,
    gh-
